So i have been trying to pull my rear seats out of my Written off sunfire to put into another sunfire i just bought but i cant seem to get them out... i have followed evey thing that the GM manual says to do and they wont come out... is there any bolts or some kind of trick to getting them out?
The First Twin Charged jbody
blue car (R.I.P) - 240whp @7psi..
silver car - 305whp 315lbs.tq @15psi (91 Octane) or 420whp & 425lbs.TQ @20psi (94 octane+Alcohol Injection)
All dynos run on a Mustang dyno
Top or bottom half? Bottom half should have two bolts under the seat horizontally pointing towards the back of the car. The top half is tricky and takes some work but you pull it down and then there is a pin on the passenger side I believe that needs to be lined up at the right angle and then it slides towards the drivers side. Its been a while since I took them out but Im pretty sure thats it.
[IMG]http://i13.photobucket.com/albums/a251/viper15230/100_1374.jpg?t=1193109920[IMG]
well i havent gotten to the top half but i will need to know that thanks
as for the bottom half... where are these two bolts? in the middle or by each window?
Just left and right of center If I recall correctly. You kind of have to lift the edge of the seat up to see them possibly.
the bottom half of the seat just pulls right out. grab it in the front and lift straight up. there are 2 clips near the front edge that hold it down. for the top half, fold it down at about a 45 degree angle and look on the passenger side. there should be a black plastic clip thats attached to where the seat goes into the side panel. pop that plastic clip off, then slide the seat towards the passenger side to remove the driver side corner. slide the seat back towards the driver side and voila, its out
