Grounding - Interior Forum
Grounding
Sunday, July 08, 2007 10:48 AM
Ok I just installed some cold cathode tubes on the interior of my car, but i was looking around and could not find a good bolt to ground everything on. Does anyone know a good bolt to use that will keep the wires hidden?
Re: Grounding
Sunday, July 08, 2007 10:51 AM
would help if you told us what car, where you installed them and maybe some other info, theres tons of bolts under your dash and under your carpet to ground too....
Re: Grounding
any piece of metal with a bolt in it, literally. there is a giant metal framework under the dash, find a bolt, loosen it, slip o ring on bolt and put back in.
Re: Grounding
Monday, July 09, 2007 6:53 AM
haha, it's a 2004 cavalier sedan. I found a good spot though, and it all works so thanks guys. It was some bolt to the right of where the sterring column goes through the firewall, i hope that is an ok location...i'll post a picture later to make sure.
Re: Grounding
Monday, July 09, 2007 9:33 AM
Don't see any reason why that bolt won't work as long as your feet don't kick it.
Re: Grounding
Monday, July 09, 2007 2:56 PM
i dont have cold cathodes, I DID but I sold em'
I just gor LED's and rigged up a terminal box and used the stock cig lighter near the floor.
(gonna eventuially make it solid, [wire to wire] instead of using a CIG adapter)
Pics avalible if anyones interested.
Anyhow, Yes, ANY bolt would work.
Just be careful of loose wires and hitting the unit with your foot (or anything)
Thrice . wrote:i think you should go back and try to actually order some cam valves. see if he has any in stock. then ask him to give you an actual price and show you the website or anything legit about where he orders from...for all you know he is this dumb, and orders things that don't exist....he's probably got 10 of those ebay transistors that gave him eleventy hundred pony power....what a douche.
Re: Grounding
Monday, July 09, 2007 7:58 PM
you dont need to use a stock bolt. get a new bolt. sand a piece on the body of the car that will be hidden. insert new bolt and ground to that. u can put a ground anywhere you want. no need to run 15' of wire just to find a stock bolt.
