Wiring up lights on aftermarket gauges...? - Interior Forum
Wednesday, June 13, 2007 4:31 PM
How many gauge lights can i wire into another circuit before the load will become an issue? I am having an issue trying to wire up the 6 gauges i have that are being lit with LEDs. I have one going into the dimmer switch, but that flickers on and off for some damn reason when i know it has a soild connection.
What are the other wires i can tap into besides the dimmer switch because i don't want to make my dash dull and dim either.
Re: Wiring up lights on aftermarket gauges...?
Wednesday, June 13, 2007 5:38 PM
My suggestion would be to wire them to your headlight switch in the steering colum this way when you turn that switch its a steady 12v source. The reason your led connected to the dimmer is flickering is do to the switch. I really wouldnt worry about the load since leds take lil to no power. hope thats gives you an idea...
Thursday, June 14, 2007 12:13 AM
Well the flickering stopped when i attached the connection thing back to the gauge cluster. It has a little press in thing on it and its no longer doing that so i am going to assume thats fixed. I tapped into my hvac wires and everything seems just peachy for now.
