well i dunno if i abused it or w/e but now my lights won't go on i turn on my lights and only my drl's and fog lamps are on. All this happened after i got my alarm installed and it was actin funny , so i messed w/ it last night and its loose when i pull it towards me like if i'm goin to put high beams. They turn on!! i let go they go back to drl's ,anyone know what can i do either replace or tighten a bolt somewhere Help! thanks....Mario!
98'zeta veinte-quatro
(z24)...... Greener tha BeRry Sweeter the JuiCe!!!!
theres torque bits i believe three holding it in and they might of tapped into it so the plug maybe lose also just remove the top of the steering colom and check it out.
the top of the cover will pop off, the bottom is held on by 2, maybe 3 7mm (9/32") bolts.
the switch is held on by 3 torx bolts, 7mm (9/32")
there are also 2 plugs, one for the cruise, one for the rest of the functions.
Its a common problem for that switch to go out, so I keep 2 for spares just in case.
