95-02 sunfire Vs 03+ sunfire dash - Interior Forum
Monday, March 12, 2007 12:48 PM
Whats the difference between the 03+ dash and the 95-02 dash in a sunfire? Is it just the top dash cover or is it the whole thing?
Re: 95-02 sunfire Vs 03+ sunfire dash
Monday, March 12, 2007 1:21 PM
The 95-99 dash is also different from the 00-02 dash.
If I'm not mistaken though, all the dash tops are interchangable. The top is the same from 95-02. If you're changing to the 03+ dash, you need the ducting as well for the vents.
Monday, March 12, 2007 2:11 PM
Wild Weasel wrote:The 95-99 dash is also different from the 00-02 dash.
If I'm not mistaken though, all the dash tops are interchangeable. The top is the same from 95-02. If you're changing to the 03+ dash, you need the ducting as well for the vents.
95-05 upper dash pads are interchangeable. You do not have to swap the ducting to change from 95-02 to 03+. The 95-02 ducts will work just fine.
The lower part of the dash structure for years 95-99 use din and 1/2 stereos, while the 00+ use double din ones. Also I think the 95-99 have a different dimmer switch for the interior lights.
Monday, March 12, 2007 2:57 PM
Thanks guys. I was looking to swap in the 03+ Sunfire dash in my cavalier since I have the infamous dash crack and I love the way the 03+ Dash looks. I know I also have to switch out door panels as well but what bout trim molding? And will I be able to use the 95-98 Sunfire Cluster with the 03+ Dash?
Monday, March 12, 2007 3:33 PM
As long as it is a Sunfire cluster, then yes it will work with any year Sunfire dash.
Wednesday, March 14, 2007 12:14 AM
I'm looking to swap to the 03+ Sunfire dash as well. I have a '99 Z24 with digital odometer so would a '99 Sunfire cluster w/digital odo be a direct plug & play with no mileage issues? Are the connectors for the plugs the same between Cavs & Fires?
Now knowing that the 95-99 Sunfire dash bottom will work with the 03+ top is a big help because I can keep my radio/CD(on top) & HVAC(on bottom) setup. I guess I would still need to remove all of the brackets, venting, etc. to install a '99 Sunfire dash? And I know I would need the door panels, too.
Wednesday, March 14, 2007 3:33 PM
Shadowfire wrote:The 95-02 ducts will work just fine.
I know it can fit, but isn't it kinda ghetto? The ducts are shaped to fit the vents.
Wednesday, March 14, 2007 3:41 PM
Not really. You can't really see any difference in them. They function just as well and you can't see that they aren't shaped to fit.
Wednesday, March 14, 2007 3:46 PM
hey chris99z,
I think the plugs are different but Im not sure, One thing I am sure of is the mileage is stored on the cluster itself, unlike the 2000+ cavs and fires that has it stored on the BCM. you would have the mileage whatever is on the particular cluster you get.
Sunday, March 18, 2007 1:14 AM
Where is everyone finding 03+ dashes?
http://www.cardomain.com/ride/2339406
Sunday, March 18, 2007 8:05 AM
^^Junkyard. Try car-part.com. You can find them with the airbags blown really cheap, and just replace the blown airbag cover with any 95-05 cover.
