Seat Belt. - Interior Forum
Seat Belt.
Tuesday, March 14, 2006 11:45 AM
The Passenger Side seat belt in my car as been locking on and off for some time, Now it's fully locked, So you can't pull it out,
Is there a special trick to get the seatbelt clutch thingy out of the car? So I can go to the wreckers and get another one.
Is there any special Tools needed? Or once I get the side panel will it just unbolt. I've looked at it and it seems to be on some kind of track.. But I did not look to close.
Any help would be awesome cause I would not mind having a working seat belt.
01 Cavy 2dr.
Thanks Team.
Re: Seat Belt.
Tuesday, March 14, 2006 12:06 PM
Feed it all the way back in and it should unlock. If not... well then it's busted.
When you pull the passenger side belt all the way out, a ratcheting mechanism kicks in which locks it as it goes back. This is so you can secure a child seat there without the belt staying slack.
Re: Seat Belt.
Tuesday, March 14, 2006 12:21 PM
yah it's busted it's stuck on full retract, It needs to be replaced.
Re: Seat Belt.
Tuesday, March 14, 2006 12:49 PM
Well as far as removal goes, I think you just need a bit torx bit.
Re: Seat Belt.
Tuesday, March 14, 2006 12:51 PM
Grate, Now I get to go out the Boon-docks and rip a seat belt out of some car that A racoon as been calling home for the last 4 months.
Joy,
Re: Seat Belt.
Tuesday, March 14, 2006 9:53 PM
try to find a car that has been in a "minor" crash, just enough to write it off, or one hit in the drivers side. after a serious crash seat belts should not be reused because they may or may not be damaged from the crash. risking death or serious injury if involved in a second crash.
just a suggestion.
http://registry.gmenthusiast.com/images/my2005cav/my%20car%20the%20bash.jpg
Re: Seat Belt.
Tuesday, March 14, 2006 9:58 PM
Wild Weasel wrote:Well as far as removal goes, I think you just need a bit torx bit.
Yea you do. I guess its size 47, but 45 works. I picked one up the other day, but haven't been able to get my off yet. That bastard is on tight.
Wide Body Progress
Re: Seat Belt.
Wednesday, March 15, 2006 9:37 AM
just a suggestion.
Yha That's What I was thinking, I was hoping to find a car that was rear ened or t-boned on the drivers side..
Re: Seat Belt.
Wednesday, March 15, 2006 11:53 AM
12 inch pipe extension worked fine for me Booger is on there at like 70 lb/ft I think. Get a pipe and it'll be off in a flash.
5K PB: 24:50
10K PB: 54:26
Re: Seat Belt.
Thursday, March 16, 2006 9:12 AM
isnt the belt mechanism attached to the body of the car with rivets? i know the piece by the floor and the piece up high is on with the torx, but i thought the actual mounting point of the mechanism and belt is like riveted or punched onto the metal.
Re: Seat Belt.
Thursday, March 16, 2006 1:35 PM
its all bolts, there are 2 rivits that hold a bracket over the belt mechanism.
