Pulling Cranks off Door Panel - Interior Forum
Thursday, September 01, 2005 8:57 PM
I want to start off saying yes I have read the FAQ, heres the part that I am referring too.
How the heck do I get these window cranks off?!
First, pull your crank away from the door panel. See that c-clip? You have a few choices here:
a) Buy the GM window crank tool at your local auto parts store (if you're not careful with this, it will scratch your panel badly).
b) Use a rag and jimmy it around the crank until the clip comes off.
c) Bend an ice pick and push the clip out by one end (this is what I did, works like a charm without scratching my interior paint!).
My Question:
Should I try taking the CRANK off first before I remove the the 4 screws on the bottom, 2 bolts in the handle, and the clips?
cause I cant get that damn thing off. Spent like an hour or two messing with it, I know I was doing something wrong
Any suggesting to get his damn thing off so I can finish painting my interior?
My Car:
1997 Pontiac Sunfire Coupe
Re: Pulling Cranks off Door Panel
Thursday, September 01, 2005 9:16 PM
Doesnt matter if you remove the screws or not...
Get a rag- not a towel....
Make the window crank face down-- Take the rag, slide it in from the bottom- holding it flat against the door panel... Slip the rag right under the main part of the window crank, slide the rag back a forth a little bit while pulling up...
The little C clip comes out from the top... Sometimes it pops right out, other times its just pops up a little bit, and you would use a small screwdriver or something to pull it out.
<img src=http://registry.gmenthusiast.com/images/reddevil/Devil.jpg>
Thursday, September 01, 2005 9:25 PM
thanks ill give that a shot in morning when i continue working on the rest of it tomorrow, ill give an update tomorrow after i finish
Thursday, September 01, 2005 11:03 PM
theres a thin plastic washer between the crank and the door panel...the rag has to be between the washer and the crank in order to hit the clip
Friday, September 02, 2005 10:10 AM
I bought the tool. Much easier. Took me like 20 sec. to get it off. Plus I keep on taking the door panel off all te time so it was worthed buying it. $5 at autozone. Saves you headaches and a lot of swearing $#@*.
stock '00 2200 cavy
Friday, September 02, 2005 6:21 PM
Juan Chavez wrote:I bought the tool. Much easier. Took me like 20 sec. to get it off. Plus I keep on taking the door panel off all te time so it was worthed buying it. $5 at autozone. Saves you headaches and a lot of swearing $#@*.
takes me only 20 secs using a rag. and i save myself $5.
SO EVERYTHING!
Friday, September 02, 2005 8:16 PM
thanks for the replies everyone, i got tht stubborn thing off after about 2 mins and then about 30 secs on the passenger side, used the rag method, hopefully ill get some pics soon my interior work. basic but hey about time i started on it.
