using spray glue for fiberglass cloth? - Interior Forum
Friday, August 05, 2005 10:46 AM
I was thinking of using spray glue to hold my pieces of fiberglass cloth in place before glassin so that they all get layed good. Anyone done this before or is this a big no no?
I am also drilling the holes and glassin from the back side. So that should hold it from coming off. I am not using it to hold it to the door just to hold it in place for the first layer of glass.
Let me know what you guys think of this idea.
Also I have asked a few people now just want to confirm as to what willl be better to do.
Lay lots of smaller pieces of cloth or a few large pieces?
Thanx.
Re: using spray glue for fiberglass cloth?
Friday, August 05, 2005 10:47 AM
I've always just brushed on some resin to whatever I'm putting the glass to and its always worked fine.
Friday, August 05, 2005 11:38 AM
well the main reason I wanted to use it was because I lay my door flat when it dries and the wrapped edges always seem to droop and fall from being wrapped.
Saturday, August 06, 2005 9:31 PM
theres nothing really wrong with it, just for most thing you need to stretch it over not sure if the glue is going to be strong enough to hold it without getting in wrinkles in it once u add the weight of the resin to it.
as far as how bit go make the cloth, i make it as big as i can easily use it witout making a mess. for an area like my trunk i was using pieces around a foot long by 6" or so wide, when doing something like kickpanels or very tight areas i may use pieces only 3" long x2" wide. it just varies on the piece and how much room i have.
Sunday, August 07, 2005 1:45 AM
the first i have nver tried
but if your using mat you supposed to do small strips so it locks togrthrbetter
Sunday, August 07, 2005 12:30 PM
does anyone know of any place in michigan where i can pick up the stuff i need for fiberglassing.
Sunday, August 07, 2005 1:05 PM
Spray glue works wonders...thats what i used when i glassed my boxes in my trunk. Also for the size of the mat, i found that the smaller they were, the easier it was to put the resin on and the stronger it ends up.
Under Construction
Monday, August 08, 2005 3:58 PM
black 99 cavalier, the cheap stuff can be found at most automotive places or most major hardware stores.
Monday, August 08, 2005 8:26 PM
what if i dont want the cheap stuff
Tuesday, August 09, 2005 4:56 AM
then try
uscomposites.com
selectproducts.com
try a car quest that sells paint.
