whats the best vinyl glue? - Interior Forum
Thursday, June 16, 2005 4:55 PM
i have searched and some people say 3m #77 is good but ive read other posts saying its bad. Im leaning towords getting 3m 08090 vinyl glue and was wondering if that would stick to plastic well... if anyone could help out that would rock!
<img src="http://i5.photobucket.com/albums/y177/mrstaticx/Mysig.jpg" alt="Image hosted by Photobucket.com">
Re: whats the best vinyl glue?
Thursday, June 16, 2005 5:01 PM
@!#$in idiot...hit the @!#$in search button and type in "vinyl glue"
what a tool...
im j/k
Vice President - NEJBody
2007 Cobalt SS
2001 Sunfire (retired)
Thursday, June 16, 2005 5:08 PM
thanks pat your awesome... again your insight has been amazingly helpful!
Friday, June 17, 2005 6:03 AM
i havnt had any good luck with 3m, none of it is high temp so after a while in high temperatures the glue will give way.
Friday, June 17, 2005 2:23 PM
Agreed ^. I also used the Select Products adhesives and they too give way when the car sits in the sun.
^CLICK ME TO SEE HOW I BUILT EVERYTHING^ How To in Interior Forum
Friday, June 17, 2005 9:55 PM
I used Elmers Spray glue. Has lasted me well over a year and still holding strong
Friday, June 17, 2005 10:19 PM
Mennitti wrote:Agreed ^. I also used the Select Products adhesives and they too give way when the car sits in the sun.
yeah i used their high temp stuff but it gave out. found some stuff my upolstery uses but it only comes in a 3 gallon can for like 70$ i'll probalby still end up getting it, not sure if it has a shelf life or not. its i believe, dap in the light blue can.
Friday, June 17, 2005 10:27 PM
to tell you the truth i work at an upholstery supply shop, the best thing to use is a glue called hybond they sell it in a gallon . you can use a paint brush to apply it and that will be the best thing to use. the 3m products or other spray glues won't work cause it can not stand heat...you can get glue at local upholstery supply shop...good luck
Saturday, June 18, 2005 6:22 PM
hmmm hybond huh? ill go check out some local shops and see if i can pick some up.... thanks for the ideas!
