My brother and I where wiring my Tach tonight. On the instructions it says to tap the green wire in the ignition system. Well the pig tail that clips on the distributor has the crank position sensor runing into it. Well it didnt work, so my prefessor in my automotive class said to tap it into the fuel injector sensor on cylinder 1 and it still didnt work. What else should I do. Oh by the way I have a 98 2.2 and its a APC Tach.
man that dirty ass engine bay look familiar
anyway in the last pic you see the wire coming off the coil pack. there is a 6pin harness (the one on the left) and a 2pin harness (the one on the right). off the 2 pin harness cut the pink wire. from the tach adaptor, there is a red wire and red w/ a green stripe wire. the red w/ green stripe connects to the wire that is in the harness. the red wire connects to the other end of the pink wire that goes somewhere in the engine bay
how much was that? and will it work with a solo shift light from summit?
98' Pontiac Sunfire SE
a tach adapter is over 100$ here
and i checked a dozen places to get those prices)
i got my autometer one (pictured above) for 60 bucks at a local speed shop
for signal tap on the white or orange.
sunstealth: get a Sunpro 3½ Tach from Canadian Tire. Readings are from 2 to 10 cylinders. I used that tach for 2 months before selling my car and it was A1.
My Car Specs
Club J-Body Montreal Forums
damnit i want a small tach to fit in a gauge pod
ill check if we have those at canadian tire ,i may get a discount on it lol im starting my third month working there
