Does anyone know were is a good place to run the wires from my tripple pod pillar in my 2004 cavalier without them getting smashed in between the door? Do i need to run them threw the dash somewhere or cut a hole some were for them?
behind the pillar. take it off run your wires then put it back on.
<img src="http://home.ripway.com/2005-1/244745/sunsig.jpg">
I did run them behind the pillar, but then they have to go under the dash to run out threw the firewall, so i still have a problem cause they go down past the pillar, and then under the dash so they are still stuck between the door and the side of the dash by the fuse box.
you can run everything behind the little cover thats below the pillar. unfortunately im not going to be removing my pod anytime soon. but it is possible to run them behind the dash all the way.
5K PB: 24:50
10K PB: 54:26
