Tomorrow I'm planning to run a 12v and ground source through my whole car so that they'll be handy for all of the new LEDs I'll be installing over the next 2 weeks. I'm going to run a red and black wire from the area under the steering column all the way to the back, then around through the trunk and down the other side.
I am completely familiar with how to take the whole front dash and doors apart, but how do you go about removing the side panels in the rear? Any help is much appreciated. I have an 03 Cavalier.
Also, does anyone know any tricks for running wire into the doors through the conduit that runs into the car? There is not much room to work with in there and I have not been able to feed anything through since there's a 90 degree bend.
Thanks!
Steve
http://www.bluecavcustoms.com
i to happen to have an 03 and here goes the back seat is bolted down , the sides just kinda pull out after u take off those stupid lil coat hookie things ......i think ... i took my interior out like 6 months ago and kinda never put it back in .... weight reduction!!!
to feed wires through the door use a stiff coat hanger, use your hands on the conduit to help feed it through, i just twisted back and forth and used my fingers to get it through the little bends. no problem at all.. then fish it down to around where the speakers are and and its done
14.82 @ 97 mph
Jasonoshawaz24 wrote:to feed wires through the door use a stiff coat hanger, use your hands on the conduit to help feed it through, i just twisted back and forth and used my fingers to get it through the little bends. no problem at all.. then fish it down to around where the speakers are and and its done
This is what I did as well..but I used an old flexible fishing pole without the hooks on it
Worked VERY swell..lol!
