I have this hole in my door
and I have the trim rings made for the 6.5" speaker
now how do i get it all together....ive been told that glass doesnt stick to our doors
Vice President - NEJBody
2007 Cobalt SS
2001 Sunfire (retired)
glass will stick just fine if its plastic....if its vinyl then you will have to take a razor blade or somethng and strip the vinyl off....
if its plastic - be sure to rough it up a little and drill holes...and glass the back as well to hold it better ( the glass will go thru the holes
Yeah, fiberglass will not stick to plastic, therefore you have to drill holes and 'glass both sides. I'm not sure if it adheres to vinyl though, I'm thinking not...
it is plastic.
what size holes and how far apart from each other?
2007 Cobalt SS
glass will stick to the door plastic, just scuff it up very good and for safety maby drill a few small holes
pjk91 wrote:what size holes and how far apart from each other?
i used a bit about the size of a pencil. i drilled holes in random patterns and distances, and worked fine
<A HREF="http://www.cardomain.com/id/eazy716"><IMG SRC="http://registry.gmenthusiast.com/images/eazy716/personal_pic.gif" BORDER="0"></A>
i suggest not fiberglassing over vinyl unless you want a big mess lol
why dont you make some edging or what i mean is build from your speaker rings close to the hole size..you can do this with plastic, fiberglass.. just build it up close to the hole cutout.have a piece of plastic - covering the outter parts of the hole, to keep the fiberglass getting on your door panel. and build fiberglass next to the plastic or hole, after its sanded, filled n leveled, then get some pressed on clips that will clip it from behind.. that way no mess, no worrying if this is going to stick or not.. and it'll be pressed tight against the hole size and hardly nobody will know it was a hole to begin with....
<img src="http://registry.gmenthusiast.com/images/its2nv4/achop.jpg">
scuff the panel with 60 grit, and then drill small holes, i drill holes that are small. bout 1/2 to 1/4 the size of a pencil. let the fiberglass resin get into the holes and onto the backside, put a layer of cloth on the backside and resin it on. this will hold fine, you now have a fiberglass sandwich, and it will hold. you allreaydy have a hole in the door so stop fretting and just try it. worst case is you have to buy anew door off of ebay, i got a pair of doors for under 100$ would have got them for 50$ but i got in a bidding war with another jbo'er lol.
lol yea...i think im just gonna go for it. i already a got a hole how much worse can it get. ill keep this updated
2007 Cobalt SS
i got real worried when i first pulled my doors all apart when the car was maybe a couple weeks old. i started thinking what the heck am i doing, then i said " well u cant put it back might as well keep going. dont worry about those type parts , they are easily replaced if u do screw up. and even if u do screw up. u would be able to break and pry the fiberglass off and u could just start over.
post pics when finished :p
