How does this piece come off...I've gotten the part around the stereo off, but the part of it around the gauge cluster dosnt wanna budge..>Are there any hidden screws or something?
LA1 Z24: Can you take the heat?
Sounds like you didn't take off the top dash pad yet?
There's three 7mm bolts that hold it.. Check the sticky at the top of the audio forum..
"If life throws you a curve, pop the clutch and drift it!"
there is 1 screw on either end, two under the glove box, and two hex bolts looking up in the glove box on a metal bracket by the airbag.
there's also a screw and a bolt in the air vent by the front windshield.
14.82 @ 97 mph
