I'm making a 3 gauge steering column pod and I need to relocate the hazards switch. I'd like to make it a push button vs the push pull switch we all currently have. I'm terrible at wiring and have tried searching. I could really use some help!!
Cheers
The hazard switch is internal to the whole multifunction switch. When you slide it over; you actually close @5 contacts inside to make all the lights flash. I could probably email you some wiring diagrams to explain, but I have another suggestion.....
Could you just build the gauge pod over the switch(maybe cut it down a bit) and just run a rod out to the right with push/pull button on the end?
Actually, now that I think about it; Im sure you could also wire in a mechanical flasher under the dash that tapped into the lighting output wires from the switch. That would give you the ability to have your T/S switch still work and then have a remote switch for HAZ.
Do you have a particular switch in mind, or are you simply looking for something as plan as a rocker switch for your hazards?
I'm pretty certain i can make this work for you. If I can, and I send you pertinent info/diagrams, can you put it all up here for others to see? I can figure it out, but I know I'll probably not have time to do a write-up here.
PM me.
Wow thanks for responding! I thought this thread would die after a couple of days. I now have hope!
PM'd
