Interior swap - Interior Forum
Interior swap
Tuesday, August 28, 2012 7:54 AM
hey i have a 2002 cavalier sedan i was wonder if a 2002-2005 sunfire sedan interior would fit and if the gauge cluster would work?
Re: Interior swap
Tuesday, August 28, 2012 6:16 PM
Yes, you can swap the interior. Quite a few people on here have done it. It's not hard, it just takes time. The gauge cluster is a direct plug and play.
Re: Interior swap
Tuesday, August 28, 2012 7:21 PM
thank you and the gauge cluster will work as long as i use a 2000-2005 one right
Re: Interior swap
Wednesday, August 29, 2012 5:57 AM
yes, the information from the cluster(miles, etc) is stored in the ECU so it will all come up on the Sunfire cluster correctly.
Re: Interior swap
Wednesday, August 29, 2012 4:39 PM
If you are swapping the dash as well make sure you search around here for the thread that explains what exactly you need (I can't find it right now.....). You will need the entire dash including the metal frame.
But yes, everything swaps.
2001 Cav Sedan LS - Work In Progress - Sunalier Status
Re: Interior swap
Wednesday, August 29, 2012 6:30 PM
i was just thinking is there any other interior that is you can swap into the cavalier
Re: Interior swap
Thursday, August 30, 2012 7:03 PM
david wrote:i was just thinking is there any other interior that is you can swap into the cavalier
No other full interior that isn't going to require a ton of modification.
