(7 with 2000-2002 Dash Bezel - Interior Forum
Wednesday, January 11, 2012 8:23 PM
Would an 2000-2002 Cavalier Bezel fit on my 97 Cavalier? I wanna have a double din radio in my car but 95-99 is only a single din.
Re: (7 with 2000-2002 Dash Bezel
Wednesday, January 11, 2012 9:26 PM
It will work if you swap the rest of the dash too. Can't just put on the newer bezel.
Thursday, January 12, 2012 12:20 PM
LOWER dash.. to be precise
Thursday, January 12, 2012 2:31 PM
What exactly do you mean by the lower dash?
Thursday, January 12, 2012 3:31 PM
where ur radio n hvac controls sit. they are flipped on a 00-04 cav. the lower dash example from gauges down. its a task n not worth it.
Thursday, January 12, 2012 4:02 PM
Steve Emmons wrote:What exactly do you mean by the lower dash?
everything under the dash topper pad.
Friday, January 13, 2012 6:22 AM
see that line going across the middle? that seperates the upper dash pad and the lower dash.
that whole lower section is what needs to be swapped
Friday, January 13, 2012 11:42 AM
Dave Premium Member Online
This part:
Its not too hard hard, you just need to find an 00+ lower dash and the trim bezel, set aside probably a whole day, and you'll need some tools, 7mm socket, some screwdrivers as well as a steering wheel puller and possibly some other common hand tools.
Edited 2 time(s). Last edited Friday, January 13, 2012 11:46 AM
Saturday, January 14, 2012 7:03 PM
Maybe a project for this summer. Just would have to find the parts and here in ND that's a task in itself. And it's almost cheaper to just order from GM and not go to the junkyard.
