cut shifter and shift boot - Interior Forum
Tuesday, July 26, 2011 10:21 AM
just got around to cuting down my automatic shifter and modifying a shift boot on to it. did not want to work at first but change few things here and there and here is the outcome. just need to find the right shift knob now to go with it
started out like this
then became this
then got shortened to this
now looks like this just need a good shift knob
Little Sedan That Could <3 Forever
Re: cut shifter and shift boot
Tuesday, July 26, 2011 7:57 PM
looks nice good job
Tuesday, July 26, 2011 8:24 PM
did you decrease your throw? very clean mod tho.
1999 - Cavalier - 5speed - Exhaust - 17" rims - carbon fiber hood - the beater
Tuesday, July 26, 2011 8:32 PM
Nice, this is in my plan real soon. So you have a manual console that you used now? Or did you cut up your auto one?
Also, any steps on cutting down the 'shaft'? Do you also have to cut down the yellow stick thing?
Tuesday, July 26, 2011 11:09 PM
i should have bought the top part of a manual console. actually though i took my console off and then modified the shift boot. a screwed the boot inside of the console in order to cover all open gaps to not be visible. i used a dremel to cut down my shifter about 1.5 inches. do not cut through the yellow part. cut the bar and wait for yellow til the end.
Wednesday, July 27, 2011 4:40 AM
u should get the rubber trim piece on there that goes around the opening. looks really unfinshed without it. u should still ahve it, came on the automatics.
david. if you cut off 1" of metal rod. then you cut off 1" of the yellow plastic piece. and as said above use a dremel. cut around the rod without cutting the yellow piece. when you pull your shift knob off youlle notice the yellow rod sits about a 1/4" higher then the rod. so when you cut the rod you want to make sure u cut the yello piece so it still sits at that same height above the rod.
Wednesday, July 27, 2011 5:22 AM
Gotcha Jason, thanks.
Wednesday, July 27, 2011 10:24 AM
sndsgood wrote:u should get the rubber trim piece on there that goes around the opening. looks really unfinshed without it. u should still ahve it, came on the automatics.
yeah i still have it. i just put it on and it does look better. but entire thing still looks weird since it is automatic console
Wednesday, July 27, 2011 9:25 PM
looks good
Thursday, July 28, 2011 4:33 AM
manual and automatic consoles are exactly the same. yours should look no diffrent now. or do you mean it looks weird becaue of the boot now?
Thursday, July 28, 2011 5:00 AM
User Chemical wrote:did you decrease your throw?
NO!
Sorry a little pet peeve of mine.
Thursday, July 28, 2011 5:17 AM
NO!
I think he was being sarcastic. I'm pretty sure everyone knows you can't decrease the throw of an automatic trans.
Thursday, July 28, 2011 9:56 AM
NO!
heck yeah you can man. i removed 10 ounces of metal and now i can slam shift my gear .8% faster yo. i won the local street drags because of this mod.
Thursday, July 28, 2011 12:15 PM
NO!
you too?! was that you that beat me on the streets then
Thursday, July 28, 2011 9:02 PM
NO!
Yes sir I was VERY clean.
Saturday, July 30, 2011 11:19 AM
Paul wrote:i should have bought the top part of a manual console.
Should have just bought a 95-99 Sunfire manual console, they look sooooo clean in Cavs
Saturday, July 30, 2011 11:29 AM
i know right. but since this entire project was spur of the moment i didnt have the part. so now i will go to junkyard and go look for the part and then will look clean!
Saturday, July 30, 2011 12:15 PM
Im heading to the yard tomorrow to hopefully find a sunfire manual console.
I tooke my console off yesterday and damn it looks tough to cut through the metal without cutting the plastic stick. Any tips? lol
Saturday, July 30, 2011 6:12 PM
I used a pipe cutter when i cut my shifter and it worked great, I had no damage done to the plastic at the end
Saturday, July 30, 2011 8:25 PM
Thanks, ill see if I can find a cheap one.
Monday, August 01, 2011 4:35 AM
i used a dremel. just hold it and dont be trying to push thru the metal. pipe cutter that small will be cheap and do anice cut as well if your that worried.
Monday, August 01, 2011 5:47 AM
David I could make you one. I have a few spares. lol I cut mine down with a pipe cutter, and a dermal.
Edited 1 time(s). Last edited Monday, August 01, 2011 6:24 AM
Monday, August 01, 2011 6:35 AM
Thanks Mike, ill just try the pipe cutter. Its only 4 bucks at Sears, cheaper than the dremel blades that I would need to buy. Plus I don't wanna switchout shifter assemblies lol
Monday, August 01, 2011 7:08 AM
Just remember how ever much you take off the outer sleeve. Take that much off the inner rod.
Tuesday, August 02, 2011 5:04 AM
Will do
