i have a 2001 Cavi and was wondering if any year sunfire speedometer is a direct fit, well is the wiring the same, i can make the mounts work
but yea, any help is aprecitated
hunter krapfl wrote:i have a 2001 Cavi and was wondering if any year sunfire speedometer is a direct fit, well is the wiring the same, i can make the mounts work
the sunfire cluster bolts right in 00+ cavaliers
yes the swap is super simple, plug and play!
can this work for 95-97 sunfire to cavalier swaps? i personnally love the look of the cavalier clusters more
AMAZING, this is my project for today. so do the sunfire dashes come apart similiar to the cavaliers? might save me a few min at the junk yard today
all 00+ cavalier is interchangeable with 00+ sunfire
i did it, no problem, plug and play like they said
www.driftnamiperformance.com
i like that especially the fact that ur radio is above ur HVAC, i wish mine was
all 00+ is like that, just get the 00-02 dash bexel and do some switching around and it should work, havent don it though so i dont know really
Model years 2000 and up are easy. Simple plug and play. Now for the model years 95-99 (esp. the 95-98), you would have to do some fabricating with the wiring. Also, you would have to match the gauges with your model year and type of transmission. For example, I did a Cavalier to Sunfire dash swap (in a 97 cavalier) and noticed the wiring was slightly different. (2 extra wires) So I had to find one that had the 4 speed (from a sunfire GT of the same year) open up the gauge to swap the ODO inside (some 98s and all 99s were digital) and then find the wire diagram that matched what wire was what. (lucky I have Haynes Manual) Then once I had it all back together, I had to do the "10 minute rule" to reprogram the new gauge due to the "theft lock" inside the gauges. Just a rough play by play on gauges I went through when I did my swap.
