hey, i'm wondering if all 00-02 cavy's have the means in place to have the rearview mirror with the lights in it or is it model specific, i dont like the tiny small mirror in my sedan and i wanted to switch out the one in the sedan for the one on the cavfire, which comes with the map lights, what i want to know is would it be plug and play or is there some amount of wiring involved, i also have the dome light that has the 3 bulbs in it with the buttons in the headliner.
any thoughts on how to do it/wire it up if needed?
www.driftnamiperformance.com
It will fit and as far as wiring it up,You will need the harness for the new rear veiw with lights,Then just pop down you factory dome light...You will see a white and a orange wire,And from the mirrior you will have 3 wires white,org,black...so just splice the white and orange together,Then you will need to run the black wire from the mirrior to a ground in the car..thats it and enjoy your new mirrior..
Jason Burten wrote:It will fit and as far as wiring it up,You will need the harness for the new rear veiw with lights,Then just pop down you factory dome light...You will see a white and a orange wire,And from the mirrior you will have 3 wires white,org,black...so just splice the white and orange together,Then you will need to run the black wire from the mirrior to a ground in the car..thats it and enjoy your new mirrior..
if thats right...its great info and very well put.
That is correct. Only difference is I spliced in underneath the driver side A pillar and tucked the wires in between the windshield and headliner
you can still tuck it with no issues,As I did on my 97 cavy
i cant for the life of me get the dome cover off, i get the pointed bit out but i cant get the 2 prongs at the wider end out... wtf
Steve-O (now with ecotec) wrote:i cant for the life of me get the dome cover off, i get the pointed bit out but i cant get the 2 prongs at the wider end out... wtf
You are making this harder than it needs to be. Stop playing with your light cover. Go to the a-pillar and splice and tuck there. No need to drop the headliner and no need to remove the alien from our roof. Hehe. I have the lighted mirror out of a Camaro in my sunfire and it took me less than 10 minutes to install including heatshrink and solder on my splices.
Yes you can go to the drives side piller also..Easy at that point.
