When working with plastic
For old plastic, use an ammonia-based cleaner and wipe down to clean surface. If the plastic is new, wipe down with paint thinner for best results. Lightly sand glossy surface if previously painted and remove dust with a tack cloth. When dry, apply KrylonŽ Fusion for Plastic according to the directions on the can.
zdoubledozen [ Matt wrote:]Krylon Fusion paint will work fine on plastic if you dont want the smooth look. It doesn't require priming. Spray and cure.
You may find a close body colour match. There's a lot of colour's to choose from.
http://www.krylon.com/products/fusion_for_plastic/
