Looks pretty good,, Measure the throw 1st to 2nd, before and after the install and also put it in neutral and measure left to right/side to side..
Looks great. I hope it works out well for ya!
I was actually thinking about getting one of these nice write up tell me how it is
Mods: Synapse Charge Piping, Short Throw, Bad-Mab Dp, Dejon Intake, BYT Tuned!
Parts For SALE! Pacesetter Header(ECO),17'in Resonator, Alternator, Starter, Viper Alarm.
......Nice !!! Waiting also..patiently...Looking to get a Ralco or the B&M...Ralco is most likely the choice.....
2003 Cavalier
Stock 2.2 Liter, 5 speed
" Leave the rice to Uncle Ben's and the wings to KFC..
Go clean or go home. "
dumb question... is that stock jbody shift base?
<img src="http://www.majhost.com/gallery/HCAJosh/crap/shooshined.jpg">
- putting the pieces back together -
whats that blue piece used for?
WildCard wrote:whats that blue piece used for?
It replaces the plastic pivot pin that you have to break in order to even get it out to allow the stock shifter to come out. Its an upgrade becasue its made of solid aluminum or other metal where as the stock pin is hollow and plastic.
CarDomain:
http://www.cardomain.com/ride/3828276
o thats rather nifty, i was able to get mine in/out tho w/o breaking that pivot pin. looks like a nice find
bump.
do i need the lockout collar? if so how do i get it to stay in place for the ralco? it came with a small pin and i can see the hole on the shaft as well...it just does not seem to quite fit...
good advice Mike...lol
everything is installed with my shifter minus that part and if anyone knows if i NEED the reverse lockout collar on there or not let me know...its on there but is not set in place in any form...reverse is REALLY hard to get into...i have to throw it hard to the right and pull down...lol any tips with this would be appreciated...other than that it feels great!
Hmm... I have the exact same one but it's not ralco.. It never came branded or anything.. I got mine on eBay for lime 50$.. Does yours seem to be loose in the shifter base? I get the same issue with 1st gear but I've just grown used to it but mine seems like the ball in the middle is quite a bit smaller than the opening it sits in
www.driftnamiperformance.com
Even the stock shifter has a smaller ball than the pivot cup it sits in...it just wears out cuase its plastic...
my new one feels great compared to the stock one...it just has a little wobble in 1st gear (as did the stock one)
i'll get a quick video to show, i'm talking like mine wobbles a good inch or more to one side, to the point that when i had my 2-12" subs in the car the shifter would wobble through certain tones..
yeah, same here...no subs yet...but i can move it to the left more than i should.
Steve-O wrote:i'll get a quick video to show, i'm talking like mine wobbles a good inch or more to one side, to the point that when i had my 2-12" subs in the car the shifter would wobble through certain tones..
My B&M wobbles pretty bad like that as well. Has since the day I installed it. Has about 3/4" of play in it.
The plastic cup is wore out.(the thing the lower shifter ball sits in).
Mine is rather loose also.
13.520 @ 98mph! 220whp 234tq
Same here with the play. Have a Fidanza one myself but very similar design if not the same.
That blue pivot that you use to lock in the shifter, what did you guys use to lock it in on the inside?
I made a clip since mine never came with anything.
Me too I used hay bail wire.
Spalattero wrote:Same here with the play. Have a Fidanza one myself but very similar design if not the same.
umm...i just put the blue piece in...no clips to be found as far as i know...i have a few parts that i had no clue where to put...but...um....its staying in fine so far...lol
(damn it now i have to go check...)
