Will any brand hub work with any brand wheel, or most brands?
Some wheels are a 6-bolt pattern so you'll need a 6-bolt hub like MOMO
Others are a 5-bolt pattern like Grant
Among the winners, there is no room for the weak
There is no bolt pattern stock, just a single splined shaft with a nut to hold it on.
As said before if you get a grant adapter you will need 5 bolt and if you get momo you will need 6 bolt.
Most people here go with the momo adapter because there are more wheel options out there.
I <3 JGM
I think bigfoot is blurry,
that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra
scary to me. There's a large, out-of-focus monster, roaming the countryside.
"Run! He's fuzzy!" "Get outta here!"
Can somebody post a link for the momo hub that will work on the 02 cavalier? Can't seem to find it...
Says that only fits the 82-94 year models... Will it still work?
David Craighead wrote:Says that only fits the 82-94 year models... Will it still work?
Im no expert but Im pretty sure as long as you have an 02 steering column it should work. Like I guess 94-02 has the same steering column. some one please correct me if im wrong though
CarDomain:
http://www.cardomain.com/ride/3828276
82-02 the same midway thru 03 they changed the steering column.
I <3 JGM
I got mine from Andy's auto sports for 80 bucks. Go with 6 bolt a hell of alot more selection.
Oh s***, he has two fire extinguishers in there!
I SATCHMOE YOU!!!! wrote:82-02 the same midway thru 03 they changed the steering column.
yes this is what I thought, thanks for actually clearing it up, so pretty much the momo hub will work with any cavy between 82-02
CarDomain:
