Center console is the same 00-05 sunfires and Cavaliers.
Not sure about the fuse door.
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
dont quote me on this.. but since the location is the same, and only minor changes made... i'd bet the fuse door is the same 95-05..
and since i had gmpartsdirect.com already open (great place to find this kinda info) i looked for you.... yes, 95-05 cavalier fuse box door.. prolly the same on sunfires too.. and its $10 brand new and likely free from a junkyard...
so you can bet the cover on the other end is the same as well... happy hunting..
search center console swap... theres been a couple how-to's... its just a couple bolts tho, im sure you could figure it out without one...
just to point out.. not all fuse boxes behind the cover are all the same. so the little stick you see on your replacement may not match up to your old one
