04 sunfire gauge cluster - Interior Forum
Tuesday, December 01, 2009 3:20 PM
replaced dash after wife wrecked it awhile back. took cluster out to see about changing bulb colors. unplugged it to take out and ever since I've plugged it back in and reinstalled everything, gauge works when it wants to. when fuel tank is full, gauge might say 1/4 full. temp gauge jumps straight to hot after just cranking for first time, etc. I've unplugged it since to see if that would reset it, FAIL. tapped on top of dash, FAIL. even unhooked battery for a few to see if that helps, FAIL. any suggestion on how to fix the problem. maybe new cluster? lol
Re: 04 sunfire gauge cluster
Wednesday, December 02, 2009 11:22 AM
im having the same problem with one of my sunfire clusters its usually only the gas one though.... my temp one did it once.. so im listening on this.
Wednesday, December 02, 2009 7:27 PM
Had the same problem here. Gas gauge would stick or not work at all. Then temp gauge would start acting up. Bought a cluster off ebay problem solved. The cluster I bought was new and it wasn't expensive either.
Wednesday, December 02, 2009 7:45 PM
Plain Jane Sunfire wrote:Had the same problem here. Gas gauge would stick or not work at all. Then temp gauge would start acting up. Bought a cluster off ebay problem solved. The cluster I bought was new and it wasn't expensive either.
preciate that. i wasnt sure if a new one would help at all.
