my ets is on i would like to know if there is a way to fix that, its the ETS and ABS.
You need to hook it up to a scanner that will read ABS codes to determine the problem. Fix that and the ETS light will go off.
2.2 97 Cavalier......the "Crapalier"
thank you!!! will get that fixed, and after my abs and ets turns off then my low track ligh will torn un when i burn rubber or no??? because that doesn't happend and it should well i think
