Your clusters! lets see what you look at
really? 99.99 percent either are stock or look stock
me and another guy were just talking about them, i just did a swap and it got me looking at new clusters that go up to 140, want to see what some of you guys have come up with
its not much but it tells me things
note; i know my tps light is on, going to the dealer soon to fix it.
Built&Boosted moar
everyones is stock. 99.9%.
lets talk about your sig that is not the right size.
Fox-02 Ecotec- wrote:everyones is stock. 99.9%.
Don't forget the grammar.
-Markus
2002 Yellow Cavalier LS Sport
Check it out! -->
Flickr
with a title like this...i was expecting tits...such a dissapointment...
snds i dig all the work you've put into your sunfire you make my hate for sunfires go from red to yellow
Did you ever finish painting your car?
I don't think you need a speedo that goes up to 140.
yep, looks like @!#$
its just all black primer atm
i think im just going to wait till i get my body kit and new hood then go have it professionally done
ill sand it back down and re-prime it, couple of the places i've looked at said they wont charge me 500 if i do all the prep work, that still leaves 2500 for paint tho,
even though it looks like @!#$ it still looks 100times better then it did with out the fade and sunspots, and the only reason i say it looks like @!#$ is a lot of orange peel and i don't know how to fill the high low spots in the paint
but not bad for my first big project, prob would of worked out a lot better if i had sprayed and not rolled on.
Josh Ferry wrote: only reason i say it looks like @!#$ is a lot of orange peel and i don't know how to fill the high low spots in the paint
Only way to fix it is with a lot of sanding.
Some people just have to learn things the hard way.
no ones ever called me a smart ass before
You need to wet sand it.
That will get rid of the orange peel. Then about 100 coats of your rattle can clear.
Wet sand again. I would work from 1000 grit +.
Cluster from the Sunfire Autocross concept car. I'll send it to Alex at BCC to be fixed one day.
here's a couple pics of my gauges.
that was before the a pillar gauges got stolen. as for the cluster, i had an indiglo overlay with a brushed aluminum bezel over it.
Edited 1 time(s). Last edited Saturday, November 21, 2009 3:38 PM
cannon fodder wrote:i had an indiglo overlay with a brushed aluminum bezel over it.
I remember rocking the same setup in my 97 Sunfire years back.
