Where the door physically latches to the body of the vehicle, there is an assembly that hooks up to the lock and handle rods. Right at that assembly I have an obnoxious rattle. Does anyone have any tips to fixing that, short of removing the assembly?
I've got vacuum tube wrapped around the rods and I've isolated them from the door by the handle, but right in the guts is where I'm rattlin'.
If I do need to remove them, what needs to be done to stop the rattle?
A piece of styrofoam works well, i think the later models have a adhesive backed padding wrapped around them.
Elaborate. What exactly am I doing with this Styrofoam?
Mine has little foam squares. What they remind me of most, is at halloween when you buy face paint, it comes witheh foam sponge applicator. they remind me of that. Just something to add some backing but not be so stiff as to prohibit the rob movement. I can grab some pics if you want? O.o
Oh and HELLO JASON! /wave
![](http://i25.photobucket.com/albums/c92/twiztidtroll/trollsig09uc.jpg)
-Saint Augustine
I turn the volume up.
Your car may do 13 sec @ 103 mph, but my car does 146db @ 35 hz.
~trOll~ wrote:Mine has little foam squares. What they remind me of most, is at halloween when you buy face paint, it comes witheh foam sponge applicator. they remind me of that. Just something to add some backing but not be so stiff as to prohibit the rob movement. I can grab some pics if you want? O.o
Mine has one of those foam squares. White ones right? Though it is pretty squished being 14 years old an all.
I might have a different plan I'll post results in "Brad's Project Thread".
yeah its the solft foam had an adhesive back and is stuck to the metal behind the rods
Spencer wrote:yeah its the solft foam had an adhesive back and is stuck to the metal behind the rods
Sup Pimp. ^_~
-Saint Augustine
My car has the foam pads already... no rattles here.
My car has the foam and still freakin rattles I found pulling the rods coser together with a shoelace to work tho. Cheap and effective lol
JGM T-SHIRTS!!!!
![](http://img37.imageshack.us/img37/1685/satchmoe.png)
