i have a mold for q sound like kick panels and wanted to see if anyone would be interested in a carbon fiber set
Kill list:03 eclipse, 06 GTO, 04 Mach 1 Mustang
I would like some fiberglass ones is possible. No CF.
is this just the piece around the feet area? not the thresh holds? if so i may be interested also... coupe and verts thresh hold molding have different shape.
ok fiberglass would not be a problem and yes it just the foot area, the stock thresh holds would possible have to be cut. it would be for the coupes till i can get a vert piece to adjust it to
ill make a set but i dont have a j-to test fitment on so i might need a volunteer for the prototype, i should be done with the first pair in a week or less
I can test out how they fit since I have the originals still I could compare them to where they came from.
JGM T-SHIRTS!!!!
![](http://img37.imageshack.us/img37/1685/satchmoe.png)
Where you located? Im willing to guinea pig.
interesting. maybe get in the way w/ clutch and foot rest when racing for me. would like to see it tho. will be pricey i'm sure.
my carDomain updated 8/10/09 Forged and no boost
I SATCHMOE YOU!!!! wrote:I can test out how they fit since I have the originals still I could compare them to where they came from. ![](/global/images/emoticons/ad.gif)
good point i will let u know when i get the first ones done, i still have to fix gaps in the mold
I'm interested! not with cf tho
need more mids in my car
i might know some ppl who would want some
been slow really busy week and now gonna be able to work on it this weekend, i have one side ready for glass but no time right now, promise to have something before next weekend
Make me a set that can hold an 8 inch woofer. I've got a 5 speed, keep that in mind too.
Your car may do 13 sec @ 103 mph, but my car does 146db @ 35 hz.
I would be interested in a c/f set.. pm me with details/pricing. I have an automatic.
![](http://i710.photobucket.com/albums/ww110/BaggedOn20s/BO20s-1.jpg)
FOR SALE
Auto is not going to matter. You'll have much more room.
one for an 8" 5 speed will be hard to do unless u got some low profile ones, but let me see how the 6.5 molds work out and ill try to make some for 8s if u can give me the depth of the subs ur running.
fyi i got the passanger side glassed and ready to pop it out and goin to be working of the drivers side tonight so satch pm me the address and i should be ready to ship sunday. they will be a quick mold so no full center cuz i plan on using a 1/8" wood ring for mounting in the real version
locdizzel wrote:ok fiberglass would not be a problem and yes it just the foot area, the stock thresh holds would possible have to be cut. it would be for the coupes till i can get a vert piece to adjust it to
F.Y.I. - having gone through the process of customizing stocks Q-forms to fit my convertible, be advised that design a kick panel to fit in one of these properly you will need more than just the threshold. That's because there is extra structural reinforcement in the convertibles in the corner area (side and floor pan) where the panel would go
that makes that space differently shaped than in a coupe.
So will have to do measurements in an actual vert; when you do, you will find that the following changes need to be made to the lower perimeter of the stock Q form panel shape in order for it to fit snugly:
- The tweeter section needs to be trimmed on both sides so it is significantly shallower
- The section where the bottom of the panel curves down towards the floor also needs to be trimmed, in stock form it is too deep
- A gap that exists towards the bottom front (towards the firewall) area of the panel will need to be filled in.
I am interested....maostly in carbon fiber, but would take a set of glassed ones if the carbon fiber costs too much....let me know prices ASAP!
"Hondas are like tampons, every pussy has one!!!"
