wanna wrap these in suede ,possible or impossibe thanks
thanks jeff
cant see the pic, but i assume arm rests?
nope looks like the entire door.
if you cut around the insert part and then put a wrapped insert piece over top that would be doable. the hard part is going to be at the front of the door near the top. going to be hard to do that without making a seam or having wrinkles. how well it can be done also has to do with how good yoru skill is. ive seen people take the easiest materiral on something like that and screw it up big time, suede isnt the easiest to work with, it doesnt stretch much and it shows any flaws. me personally, if your not that good i'd look at having a qualified shop do it.
very possible, but you really better know what you're doing or have someone that does. i'll post a pic of my interior.
What's better than having
a car with a turbo?
Having 2 cars with 3 turbo's
Just about anything is possible to upholster. You just have to do it right.
Getting suede on there will require a lot of work, but it's doable. Hope you can stretch fabric.
Interior FAQ -
J-Body of Michigan -
well whats a good fabric to work , i dont want vinyl or something cheap lookin
well if you cheap out on the suede fabric. itll fade over time. i use faux suede on my headliner and rear deck. but those parts hardly see sun. where as the top part of the door would fade after a couple months possibly man. unless you use real suede. btw. faux suede stretches fairly well
I NEED a 97-99 LD9 engine harness for an auto.PM if u hav info.!!
thanks rick , im kinda afraid to start this
Don't be afraid. Its something new and it'll never get done unless you just go out and do it or pay someone to.
http://nwgme.org
William Senefeld wrote:very possible, but you really better know what you're doing or have someone that does. i'll post a pic of my interior.
Is that the one soundz plus did like back in 03-04
The passenger side door panel has a white lower half while the driver side doesnt. Am I right or am I seeing things?
Right place, wrong time, right person, wrong situation
