Touble to install a tachymeter on a swap 3400 - Interior Forum
Tuesday, March 31, 2009 4:26 PM
I need help to find the tach signal on an Alero 3400 1999 swamped into a cavalier, some people say to find the white wire that goes into the ignition control module, but I don't find this f***ing wire, I try different wire, but the rpm reading it always wrong, I used a scanner to get a good rpm reading. If someone have any suggestions ?
Re: Touble to install a tachymeter on a swap 3400
Wednesday, April 01, 2009 4:11 AM
Your going to need a tach adapter. I bought mine from Summit racing for about 40 bucks or so, just follow the directions and make sure you switch your tach to the proper cyl. # you have.
Wednesday, April 01, 2009 6:04 AM
Ok, thanks i will bought one and install it.
Monday, April 06, 2009 9:12 PM
Agreed. Theoretically, the purple wire on the ICM could work, but when I tried it, my tach cut off at 3k.
Saturday, April 18, 2009 3:12 PM
I find an easy way to solve my problem, i used an equus tachymeter (8068) with and inductive pickup that you simply put on a spark plug wires. Check the RPM with an scanner and it works well.
