Does this Alpine stereo fit the cavalier ? - Interior Forum
Saturday, April 11, 2009 5:18 PM
i have read in those forum that some people said they had this stereo installed in their cavies, my cavalier is 2004 sedan and at Cruthfield
http://www.crutchfield.com/p_500CDA9886/Alpine-CDA-9886.html?tp=5684
says that this stereo won't fit my car
for example this guy in gm delta forum has this stereo
http://www.gmdelta.com/members/00crazycavalier/cars/3/
i think he is mantaz in this forum
mantaZ
on crutchfield i selected chevy cavalier 2003 coupe just like mantaz's car and it says wont fit either
does anyone else has this stereo installed? pictures would be awesome
Re: Does this Alpine stereo fit the cavalier ?
Saturday, April 11, 2009 5:25 PM
yes I have the same one.
Saturday, April 11, 2009 5:26 PM
crutchfield lies. you might have to cut osme plastic out from inside the dash. but 90 percent of people do it just for the extra room anywyas
Saturday, April 11, 2009 7:38 PM
DaFlyinSkwir(LS61) /PJ/ OEM+
did you install the stereo yourself? do you have pics available?
I knew crutchfield dont know @!#$ about that and also overprice their products
alpine 9886
here it is for only $239, at crutchfield is 299 but they send you a cable and instructions to install it yourself i think
Sunday, April 12, 2009 6:45 AM
I have the same one installed. We did have to cut some of the plastic from the dash to get it to fit but no biggie. Install is pretty straight forward to do yourself. You will need a dash kit, antenna adapter, and a harness from a 2000 metro. You may need to do something different if you have the upgraded sound system from the factory. If you don't then all you have to do is match up the wires from the metro harness to the head unit. Take the dash apart, remove the old radio (held in by 2 bolts, unplug the antenna and wiring harness) and install the new one. The only other thing is you are going to need to run a power wire from the head unit over to the fuse panel. Just make sure you wire it to something that comes on when the ignition is turned. I don't have any pics from the install but here is one of it installed.
Sunday, April 12, 2009 7:46 AM
The reason they say it wont fit is because many, if most of the aftermarket players are longer than the stock cd player.
This requires you to cut the plastic behind the dash as stated above.
Crutchfield says it wont fit because it is not a direct bold on in the sense because slight cutting is required...
Monday, April 13, 2009 1:28 PM
i love the blue trim, what is the paint color, or paint code ^^
Monday, April 13, 2009 2:52 PM
It's Daytona Blue from a Nissan 350z
