Crank to Power Window Install Problem-Need Help! - Interior Forum
Saturday, March 28, 2009 12:43 PM
ok so i got the base model LS with Crank windows...i wanted power now..so went online and bought the motor and regulators... and then went to a junk yard and got the switch... got the power motors all mounted in doors and they work perfect., but now here is my problem. i want to install the stock GM switch, but i do not have the harness... can anyone tell me if i can buy the harness from the dealer and how much? or can i run wires to the switch and motor myself? if so how? nothing is labelled so i would need some drawing of somekind. any help would be greatly appreciated. Thank you.
Go Low or Go Home!
Re: Crank to Power Window Install Problem-Need Help!
Tuesday, March 31, 2009 4:54 AM
I would say your best bet would be to try a local salvage yard for the harness, but basically if you get power to the switches the motor usually has two wires one is up and the other down, they would wire into the switches by way of relays of course don't forget the relays even if you find a harness.
Monday, April 13, 2009 8:18 AM
i had the unverisal spal kit i connected to the stock switch, go the junk and cut out a stock switch with harness
Mods: Synapse Charge Piping, Short Throw, Bad-Mab Dp, Dejon Intake, BYT Tuned!
Parts For SALE! Pacesetter Header(ECO),17'in Resonator, Alternator, Starter, Viper Alarm.
