Can I run this tire size with the Tokico Dspecs and sportlines? I hope so because I know these are the closest tires to run to keep the speedometer as accurate as possible.
that is the correct size for a 17" rim.
can i still run it with a drop? or better yet, is the geometry of the bottom of the strut the same from the stock to the dspec? is the spring seat the same distance from the bottom?
What the.... YES you can lower the car with these tires.
Thank you for a simple straight answer. I obviously know they are the right size for the 17 hence the reason I am running them.
