well this summer i am going to have my car repainted the fenders will be rolled and i will be in the market for new wheels and will finally install my ground controls on my koni yellows. I have been looking at alot of nissan 240's and s2000's and love how theyre wheels are right at the fender as if its almost rubbing
LIKE THIS i know are cars arent 240's or s2000's but is there any way to at least get the rim to sit flush with the lines of the car? wat offset would i need to run? i hate how my rims look all sunken in, i dont want the camber or anything like that i just would like to know wat offset i should be running to get the rim to sit flush with the bodylines of the car, thanks guys
might be another dumb question but does anyone know if they make ccw classics in our lug pattern>? i figure they make emfor civics why not for a cav? they super expensive though
or anyone know of any wheels similar to ccw classics? i love those wheels
ok instead of making a new threadddddd one more question haha anyone have a list or know any manufacturers other than konig that make the wheels with the prizma lip?
The stretched tire look isnt very popular with this crowd so you will have to do some testing and figure it out for yourself. Basically the key to pulling that off is wide wheels and stretched sidewalls. I'm a big fan of the "demon camber" as they call it in japanese car circles. I think it really helps to pull that look off.
Before buying rims, measure the offset of your current rims and add spacers until you get the offset and fitment you like, then do the math and find out what offset you are looking for.
This page will help with tire size. A friend of mine owns a used tire shop so I can play around a little and see what fits best but you'll just have to do some measuring and take an educated guess.
Sorry I couldnt help out more and show you some numbers.
thanks guys, one more question with spacers am i gonna need longer wheel studs? if so are ARP the only company that sells em? or can i find em at autozone for a different car?
im debating order the 5mm studs since i think i may want to space out the rear a bit more than 35(just rolled my fenders theyre pretty thin now) were can i get longer studs? is there any cars were i can get the studs from at autozone or advance auto that have longer studs?
this is a good question, im interested aswell.. it seems to me that the back wheels usually tuck big time and the front wheels stick out on a lot of wheels... im wondering wat backset or offset is needed to get the back wheels out flush and the fronts in flush? ive got a sunfire but i figure its the same for a cavy.. im kind of a noob to the j body community
SC454SS wrote:this is a good question, im interested aswell.. it seems to me that the back wheels usually tuck big time and the front wheels stick out on a lot of wheels... im wondering wat backset or offset is needed to get the back wheels out flush and the fronts in flush? ive got a sunfire but i figure its the same for a cavy.. im kind of a noob to the j body community
I've noticed this problem a lot in the past year, mainly because I was trying to pick an offset for my new wheels. It's also VERY notice-able with my Type-J sides. Unless someone else has a better idea, I think the only solution would be to get a different offset in the back, versus the front. Or, lengthen the studs in the back and space the wheel out.
Agent Omega wrote:SC454SS wrote:this is a good question, im interested aswell.. it seems to me that the back wheels usually tuck big time and the front wheels stick out on a lot of wheels... im wondering wat backset or offset is needed to get the back wheels out flush and the fronts in flush? ive got a sunfire but i figure its the same for a cavy.. im kind of a noob to the j body community
to be honest the i actually think the back is perfect in most cases.. its the front that annoys the crap outta me. i hate it when a wheel is sticking out of the front fenders
^^you need the knurl dimension too.
I'd stick to stock offset (in front especially) due to scrub radius.. the rear its not as important but I believe track width in the rear will effect turn-in and how the car "rotates" through a turn.
could be wrong.. suspension is still a bit voo-doo to me.
interested as well. there is no way of having a lip in the back? wheels wouldn't be able to be rotated but I think it'd look beautiful. lip in the rear like they do on the 350z. by no means am I trying to make people think my car is rwd just want to push the rear tires (rims) out flush giving it a "no gap" look all around. of course the car would set lower in the front to follow the body llines. a great (much safer) alt to wheel spacing for dd use imo. although I don't know that much about legthened studs either.
