Not a total newbie but i could not find any information regarding how wide in inches a 205/40/17 tire is. I bought these D+C rims off craigslist which had new lexani/nexen N3000 tires on them(205/40/17) and now one of the rims is cracked another is bent and so on... I assume they are 17x7 but the rim doesnt say. I have looked all over the internet and cant find these rims for life of me, thus not being able to find out the exact size. found another set of rims which i dig but they are 17x7.5 and am trying to find out if the tires i have will fit. Does anyone know what "205" translates into inches? I apologize for my ignorance... hopefully someone can help
thanks.
GREEKROCKSTAR
If you are running these on a Jbody
You should be running tire size 215 45 17 or even better 225 45 17
its an '03 cavi.... what would be the advantage of those sizes?
GREEKROCKSTAR
225/45/17 is the correct size tire for a 17inch wheel on 3rd gen j-bodies
Edited 1 time(s). Last edited Wednesday, June 17, 2009 9:23 AM
JGM T-SHIRTS!!!!
so lets say i go with that size tire... how would i go about knowing which ones will fit a 17x7 or a 17.5?
GREEKROCKSTAR
it will fit both without a problem.
JGM T-SHIRTS!!!!
i guess that means i got to buy new rims and tires... thanks for the info
GREEKROCKSTAR
im going to get new rims and tires but can anyone tell me why its a bad idea to use 205/40/17 tires? What is the advantage of using 215/45/17 or 225/45/17?
GREEKROCKSTAR
those two tires sizes are the closest to the stock tire size... with a 17" rim. that and you will have a bigger foot print. your size would be way to small for the jbody.
so heres the deal.... i was talking with a guy from victoriatire.com and he was trying to tell me i shouldnt go with the 225/45/17 that i should stick with the 215/45/17. i tried explaining that the 225 should fit then he told me he would put those on but he doesnt think they will fit right.... is he nuts or????
GREEKROCKSTAR
Go some where else.
225's fit without any issue at all. Hell thats whats on my car right now.
JGM T-SHIRTS!!!!
haha people run 225s on jbodies all the time.. crap im running 225 rite now also
well i ended up ordering em with the 225, im not using hub rings with the current setup wondering if i should with the new set. I have heard people say i should and other say they dont so.....? i would like to think that i only need them if im getting vibrations or anything like that, is this true? is there any other reason i should be using them?
thanks.
GREEKROCKSTAR
john karouzos wrote:well i ended up ordering em with the 225, im not using hub rings with the current setup wondering if i should with the new set. I have heard people say i should and other say they dont so.....? i would like to think that i only need them if im getting vibrations or anything like that, is this true? is there any other reason i should be using them?
thanks.
I would definitwely run centering rings, I didn't on my first set of 17's and I snapped studs rightand left from the wheel not centerin gon the hub correctly. I've got them on now with my new wheels and I haven't had any problems. Better be safe than sorry I think...they aren't expensive at all.
with 205s, your speedo will be out of wack by a lot. But the will fit. But of course it all depends on your stock engine. (z/gt 2.4 or base 2.2)
My speedo is off by 3 mph with 205/40/17
Twisted Cav(sdwndr2) wrote:My speedo is off by 3 mph with 205/40/17
Thats not too horrible... i had 205/40/r16s on my stock 96 gt rims, and the speedo was way off. Speedo would say 75, and i would only be going like 68 or something lawl
I don't even pay attention to the difference anymore, I just drive with the pace of other cars and go by what my speedo says.
225/45/17s if you go with a 17x7.5 wheel. 215/45/17 if you go with a 17x7. If I remember right 215/45s are closer to stock size, but 225s will give you more sidewall to protect the rims.
Shadowfire wrote:225/45/17s if you go with a 17x7.5 wheel. 215/45/17 if you go with a 17x7. If I remember right 215/45s are closer to stock size, but 225s will give you more sidewall to protect the rims.
If your going with 17" rims the right tire size for speedo is 225, it gives better traction too because of more tire being on the ground. Check the tire guide at the top of the page. It tells all. =P
Thanks to everyone for your help. The guys at victoriatire sent a set of hub rings and new lugs with the rims/tires even though i didn't order the ring and lug package so i guess i came out on top. I couldn't be happier with the 225's. I live in chicago and the streets here are terrible, in some cases its almost impossible to avoid potholes, bumps etc. The 225 gives a nice ride and can take some hits without concern of bending or cracking the rims. Now time to lower the girl(maybe 1" front / 1.7" rear), pop in a new intake and exhaust. Any suggestions on which to do first seeing as cash is a little tight? As soon as i get off my lazy ass ill post some pics and add one for my sig.
GREEKROCKSTAR
