I just bought kumho tires(215,45,17) with camber/toe wear on the one side. its pretty bad like the last inch of the tire is bald.... but the rest of the tire has 90% left tread.....
there are directional tires, my question is. when i mount them on my rims, if i put the worn side to the outside of the rim, so the the camber is now reversed,
will i be able to get some good use out of them?
i took a chance buying them i get that but its was 80 bucks for the two tires, but the rest of the tire is 90% the worn part doesn't even touch the ground im pretty sure
thanks guys
You could have bought decent new tires for twice the money
Don't know if you can use them but i wouldn't
yes you would be dismounting the tire and flipping it to the opposite side of the car. Say if the tire was on the drivers side, dismount it. flip the tire, then mount it on the passenger side so it's still going in the same direction.
for like 30 more bucks you could of bought two brand new kuhmo's. I have a set on my car right now and bought them for like 55 or 60 a piece. The01Cav hit it on the head though, you would have to dismount the tire from the rim and mount it in the correct direction.
