Double checking wheel/tire info - Wheel and Tire Forum
Wednesday, February 11, 2009 9:23 AM
I am planning on putting on a set of the Falken Torque 5 17x7 wheels w/40mm offset and 73.2mm bore. on those wheels I want to put a set of 225/45 tires. from what i have read that should all fit i think but would like someone to verify that in case i have missed something.
thanx
spark
Re: Double checking wheel/tire info
Wednesday, February 11, 2009 9:24 AM
i suppose i should mention i have an 05 cav LS Sport with a stock suspension
Wednesday, February 11, 2009 11:02 AM
make sure there 5x100 bolt pattern!
WiGM-Tuners member.
Wednesday, February 11, 2009 11:58 AM
tire size is fine.
offset is fine.
make sure bolt patters is correct (5x100)
make sure you get centering rings. 73.2mm is like 25 mm bigger than it needs to be.
1997 Cavalier Z24
Bomz Short Ram Intake
Vibrant Cat-Back
KYB GR2 Struts
Goldline 1.75" Springs
RK Sport Upper Insert
RK Sport Lower Dogbone
Custom Tune by Shane @
innovativetuning@rogers.com
15.647 @ 88.02 MPH
Wednesday, February 11, 2009 9:44 PM
excellent thanks fellas
