wondering ?? - Wheel and Tire Forum
wondering ??
Sunday, October 19, 2008 7:44 AM
Ok i tried to look for it can 235/45r17 fit . I try to search and on the forum and it did not answer my question. Will it rub or not im on a sportline drop. I just want to know cause i can get the tires for free . thanks
Re: wondering ??
Sunday, October 19, 2008 8:18 AM
The simple answer is that it will likely rub. Although they are not significantly taller or wider than the 225/25/17, on a sportline drop, I believe the difference is enough to likely cause problems.
However, it might work, depending on your wheel width and offset. You can't necessarily make a blanket statement about a tire size fitting without knowing the rim info.
Re: wondering ??
Throw them on there and find out
Re: wondering ??
Sunday, October 19, 2008 8:27 AM
If you are getting them for free then who cares. Just try it out.
