Whats up guys My 97 cavalier z24 wont stop vibrating on the free way. Got new tires didnt go away, got new wheels still there if not worse. What do you guys think the problem is? this is getting really frustrating. It starts from like 45mph and up. Just had an alignment, and new struts. The cars got 150k and drives straight as an arrow. Anyone got any ideas or same issues? Thanks...
try your rotors, maybe they are warped....bent axle shaft, bad wheel bearing, missing loose hardware ANYWHERE in the suspension, there are a lot of things it could be, more details about when and where and how and all that would be great.
Just did new brakes. sway bar bushings also. How can you tell if you have bent axle shafts? What do i look for?
Not sure how to tell, but its just a possibility, maybe some others will be able to give ideas.
I drive over 100 miles a day and cant take much more..
give us a little more info
stock wheels?
how were the tires balanced? (static/dynamic)
are there any weights on the wheels?
AHh I found the problem. It was the tires AND they were new from belle tire I got them to put a new set of 4 on and its smooth as rails they were the kelly explorer tires= JUNK.
