i have a 96 cavi with stock 14 inch steelies and was wondering if a set of stock neon wheels will fit on my cavi
oh boy, here we go again.
next you'll be asking if you can get Cobalt rims on right?
j/k
what? i thought they did ? and isnt the cobalt a jbody anyways ?
i joke i joke i kid i kid ...
AZ24Ncav wrote:what? i thought they did ? and isnt the cobalt a jbody anyways ?
yea, your right. the ion is a jbody tho right?
lol. i'm joking.
WiGM-Tuners member.
whats so hard to believe, guys?
neon's have 5X100, same as j's.
ok .. wel i didnt know that the srt-4 had the same bolt pattern since it has factory 17s or 18s i searched neon cavalier wheel swap and it didnt come up with anything.. just making sure
what else on the 2000 neon will swap over to my 96 cavi
the motor is a DIRECT BOLT ON!!! you should try...
brokedown cavalier wrote:what else on the 2000 neon will swap over to my 96 cavi
well since the neon is from dodge (chrysler) and the cavalier is from chevrolet (GM) EVERything will swap over
OH BOY
Member of JBO - 9 Years & Counting...
im sorry i sound like such a newb but i pretty much am..
look bro. either try more searches (cuz yours was pretty fail if that's all you searched for and just dropped the ball), or ask in the newb's forum. alot less flaming for askin there. now, with that said, good luck!
if they are the same bolt pattern you should have no worries other than backspacing if you have to much backspacing put a spacer in, if you have to little backspacing have the back side of your rim where it meets the hub ground down, if its not the same bolt pattern and you have enough backspacing you can use an adapter, if you dont have enough backspacing, then your hubs will need redrilled, as long as you have enough metal on your hub, and the bolt pattern doesnt get to close to the edge or outside the edge of the hub everything will work fine, although, it might cost a little big of coin
