Any way to cram these under a Cav? What rim size also... 8 or 8.5? Is a 7.5 possible?
*2000 Cavalier sedan*
i have 235/45r17's on i believe a 8 but might be 8.5 on a sunfire lowered a 1.5 and i don't have issues with those and i can go a lil bigger yet if that helps.
Thanks. That helps a lot!
Anyone know of any 16x8"+ wheels? Lightweight needed. This is going to be my autocross wheelset.
i have a set of 16'z with the 205 /55/r16's and before lowering i had a lot of room and when i lowered it i still did. but i do have maybe a half and inch from my spring perch with my current set-up maybe a lil less.
I just did i tire caculator just being curious height wise you would be fine but the width would be pushing it might clear and might not. With that set-up to mine those tires would just be a hair of 3/4 of a inch wider which i am sure i could clear on the black but not sure on the front but would also depend on the off-set of the rims. I'd go with Quiklilcav and possibly go smaller. And maybe u should go his sizes the 225/ 50 is the same width as my 225/45/r17 which is 8.85 inch wide. The 235/45 a 9.25 inches wide. Neither4 should throw your speedo of by more than 1.5 mph.
