Just wanted to see if this car was still around? Are those 22's? They look bigger than 20's .
yes they are 22's, his name on here is 20'sn22's (bagdfire) or somethin like that i think
22 rear, 20 front
If you have CF engine bay pieces, SELL THEM TO ME!
Built Not Bought
yes thats his car. if your looking for the name of the wheels they are tis style 07
could he run 22 in the front ? If they were 7.5 in wide?
if he hacked up the whole front of his car sure but thats alot of work to make 22s fit up front
What size tire would that be?
I'm guessin these are his new wheels .
Still wondering why not running a 22 in front. The rim is a 7.5 why shouldnt this work?
only asking ..
the first ones are his new rims
there is alot more involved then just the width of the rim. yes you can fit 22s in the front but you would have to lift the car so when you turn, the tire doesnt rub on anything.
if you want it slammed like his car, there is a ton more work involved. look at the rear and see whats involved in that. in order to do the front, you will have to pretty much cut out the wheel wells, widen the fenders, move alot of items in the engine bay, etc... im sure theres much more thats involved in it.
the 22's are 8.5 wide and the offset is 35mm. and i think the chrome rims are his new ones i think i remember him saying his putting the "flower" ones on his girlfriends car.
ok so you can fitt 22's on front .. 22x7.5
But you have to lift car all the way up to ride right?
you can fit 40" rims if you want as long as its tall enough to clear the wheel wells so you can turn freely
what striped is getting at is if your basicly running on easystreet bags on the front or any bolt on air product on the front you will not have enough lift to turn your wheels. you will have to make your own front suspension to get enough lift to run 22's in the front. is it possible for sure but how much do time and money do you want to put into is up to you and when you can just throw a 20 on there it makes it a whole lot easier
ok thanks . sound like somone knos what their talking about.. Thanks
have fun stopping and getting that thing going with that large of a rim tire.
You cant sport 22's in the front on air because I believe the frame would sit on the tires. When spyderwizard flipped his easystreet mount to drop like an inch lower his stockers sat on the frame. BUT...even on air sitting on the ground 20's look big.
STREET ANTIX, it's coming...
you mean the wheel wells? jbodies dont have frames, they are unibody cars
All of that rolling mass, and he is sporting stock brakes.... priorities man, priorities.
1983 Camaro Z28
i believe hes working on that brake situation right now.. Its a Show Car I'm sure it really doesn't go to far from home..
