So I got a 04 LS Sport with the chrome rims. How can I clean these suckers up. I've bought some armorol chrome wheel cleaner, but it does not remove all the browns brake dust build up. I've sprayed tons on it with no luck. I need something strong.
What do you guys recommend?
P.S: I'm in Canada
first please post in the right forum. secondly becareful on what you spray on your wheels. some cleaners will @!#$ up your wheels. you should clean them more often this way the brake dust doesnt build up that much. ive always just used water to clean the wheels. i never had a problem. also try switch ti ceramic pads, that will help create less brake dust.
Try some compuond then polish
z28guy(KGM BEOTCH)
if you have a dollar genaral in your area there is a product i used in my detailing shop called awsome its not expensive and works great or if you can get your hands on some wheel acid that also works but you have to rinse it off imidiatly
try a magic eraser, with a light touch it should work ok I would imagine
For stubborn dirt. Try using paint cleaner.
chrome polish ftw....it takes some elbow grease un less you have a mothers powerball
