I'm kinda new with aftermarket rims and i had a few questions. I was thinking about getting the HPD poison series, flash 6 or spinout. The flash 6 has a 42mm offset and is a 17 x 7.5 inch rim. I have a 2000 cavalier Z24 at stock height. Will i have clearance issues if i lower it, and will they stick out at all as is? Also should I go for the 215/45R17 or the 225/45R17. The only thing i'm worried about really is getting these rims and then having them stick out really bad due to the width difference in the wheels. Any help would be great
no a 42mm offset is fine. also either tire will work. if you want to tuck, a 215/45/17 would be alittle easier to tuck
