17 inch wheels, what is the best tire size to go with? - Wheel and Tire Forum
Wednesday, March 28, 2007 1:47 AM
I know there is a sticky thread above about what size tires you should go with and the error margin with the bdifferent sizes; but it looks as if all sizes will have a error margin and throw of the speedo in some way.
Is there a size i can put on 17's that will not throw off the speedo, or basically its such a small error margin that you will not notice it.
I just solod my 15's, now i want to upgrade to my first set of 17's, i dont want to low of a side wall, 215/45/17 be good, or is 205/45/17 better
Please help, i need to find rims and rubber soon..
Thanks very much..
98 j-body sedan
Re: 17 inch wheels, what is the best tire size to go with?
Wednesday, March 28, 2007 2:37 AM
225/45R17 will get you closest to stock diameter, smallest you should go is 215/45R17. Try and get a rim with a width of 7.5" but no less than 7" I believe the stock offset on our cars is +42 bolt pattern is 5x100. Also make sure you get hub centering rings discounttiredirect.com sells metal ones for around $12->$16 usually shipped just call and tell em the rim and the car and they give you what you need. 205/45R17 will be WAY to small,
couple places to look for rims and tires.
edgeracing.com (checkout the flik rims good price and great looking)
tirerack.com (typically more expensive, but great service)
Those 2 are very reputable and you can feel safe sending them your money. Edgeracing is always running specials at least once a month on wheel and tire combos, also being the end of march people are going to want to start getting rid of their inventory for the quarter before taxes hit.
-Chris
Wednesday, March 28, 2007 7:44 AM
Thanks man, actually according to the tire calculator 215/45/17 are closer to the stock diameter then 225.
98 j-body sedan
Wednesday, March 28, 2007 12:58 PM
I have 225/45/17.... fills the wheels gaps nicely.
Words that you can't use in modding: Finished, Perfect, Cheap.
Thursday, March 29, 2007 1:54 PM
Get the 225's. They will ride better, and fill the fender well better.
Monday, April 02, 2007 9:16 PM
ive had 215/45/17 and now i have 225/45/17 and i like them better but you can also go with 235/40/17 if you want a wider foot print.
12.7@110MPH with 10PSI.
Monday, April 02, 2007 10:10 PM
I have 215/45/17's on mine and dropped on Eibach Pro Kit springs, they're close but clear nicely and look good.
Monday, April 02, 2007 11:49 PM
i had 215/45/17s on my old rotas.... there a nice ride .. but i recommend going 225/45/17 .. you will love the difference it makes
Tuesday, April 03, 2007 5:45 AM
Go with the 225s. 215/45/17 is what came on my tC from the factory, and I made the mistake of not switching to the 225s when I bought my Pole Positions. The sizing difference is minimal, but the traction that the extra 10mm will provide is very noticeable.
1989 Z24 Convertible - Dust Covered
2006 tC - Dust Covered, but driven more
Tuesday, April 03, 2007 5:13 PM
225/45/17
