http://store.racinglab.com/5zfnrawh1711.html
im looking at that rim...do i need 5x100+35 or 45 mm?....
i also saw that someone bought a rim that looked like this (i think it was rota) and had to have it machined to fit...anyone know anything about that?
I <3 3COT3C!
www.IZNTRBL.com
they have a +48, and a +35
+48 should be okay, unless you're planning on running a big brake package, such as the Wilwoods. I'd then suggest the +35
Desert Tuners
what is the +45 and +35?....and will i end up having to get the wheels machined to fit?
I <3 3COT3C!
www.IZNTRBL.com
that's the offset, or how the rim sits in relation to the center hub on the rim. the higher the number, the farther in the rim sits. the lower, the more out the rim sits.
so, if you have a big brake package like the Wilwoods, the +48mm might not let the spokes on the rim clear the brake calipers. the +35mm certainly should.
Desert Tuners
Ask the retailer what the hub bore is on the wheels. J-bodies have a 57.1 mm hub bore. Usually higher offset wheels (48mm+) are made for subarus, which have a 56.1mm hub bore, thus the machining requirement.
"The J's weren't designed to be sports cars, the suspension sucks, the brakes are tiny, and the target market for our car doesn't need to be able to do any more than 65mph." - Shifted
A more accurate observation has never been typed. These should be the starting points before any serious performance modification. What's the point of making a serious performer if you can't control it's power?
get the 5x100 with the 48mm offset. youll be fine. also your going to need hub rings anyway. hub rings are going to take the weight off the studs and center the weight on the hub. the bore size for these wheels are 73.0mm and as said above our hub size is 57.1mm. you can get these from discount tire, just call and ask for them. say you need hub rings with an outter diameter of 73.0mm and an inner diameter of 57.1mm. should cost about 15 bucks for them. your going to need new lugs too. i suggest mcgard spline drive kit. best lugs i ever owned. lug size you need is 12mm x 1.5mm
hey, thanx alot...im not gnna be doing this for a lil while so ima save all this info and try and buy this stuff in march...what would u guys recomend me getting 17x7, 7.5 or 8 ?....i was gnna go with 7.5...good choice?
I <3 3COT3C!
www.IZNTRBL.com
I like them. Works well with a 225/45/17 tire.
id stay w/ either a 7 or 7.5 wide
Since our wheels stick out in the front and are sunk in in the rear, i'd go for +45 in the front and +35 in the rear.
I wish my wheels would have come with multiple offsets in 5X100...
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
^^ you could also do that if you want
yea i think i will....thats the main thing i hate about the cavi....it kinda looks funnie.....
I <3 3COT3C!
www.IZNTRBL.com
i like it cuz i have air ride
yea ...really get those tires tucked away! haha
I <3 3COT3C!
www.IZNTRBL.com
