I will be purchasing a set of 18" Enkei RSV's and am currently running on sportlines, and I was just wondering what kind of an offset I should be looking for so that things won't rub, I was thinking a 42, but not sure if that will rub. The rims are also offered in 35 mm offset.
42 would be fine. 35mm might set the tire out too far and it will hit the fenders.
Desert Tuners
45 would be the other offset and not 42 but I would imagine that would be fine to go with the sportline set up?
45 is fine
45 is fine, but you might have issues if you went with a big brake setup like the Wilwoods or Baers.
Desert Tuners
I don't plan on a big brake conversion anytime soon, so I should be okay. Thanks for the info fellas it is greatly appreciated! When I get them on I'll post some pics so you guys can see. THANKS AGAIN!
i had 42 never had problems
What is the conversion to go from mm to inches, I just bought a set of Riax Seca 18" x 7.5" with 6" backspace and I'm trying to figure out if they'll sit under, out or just right. any help here?
2000 Z24 5spd header & catback for now.
theres 25.4 mm per one inch.
I found the info I needed on my Seca's they're 45mm offset, so I should be fine with the Tien Super Street coilovers.
