i just called wheel max and they say the rh5 has been discontinued
this really breaks my balls because i have three perfectly good rims, but one that needs replaced
so there is a possiblity i will be sittin with three perfectly good rims, that are utterly useless
Your best bet would be to contact Exel directly and find out from them whether or not the RH5's have been discontinued.
Good luck getting ahold of exel... I've tried countless times to get ahold of them about centercaps for the RH5's and got no reply in 3 months.
well you could search around for other distributors and you might find 1 somewhere...........i know my buddy wanted discontined wheels and they literally came 1 from each of the 4 corners of the country
*************Yea i spell liek wrong get over it*****************
** If i write in caps its cause im @ work and i can only write in caps cause the keyboard is a retarded CAPS only keyboard.**
rh5 has been discontinued for a while. also, exel is the brand name of wheels that wheelmax created. hence, why you only see wheelmax carries them. so i'm 100% sure that if wheelmax tells you no, then you can believe its a no.
![](http://registry.gmenthusiast.com/images/viper98912/newsig2.jpg)
really? I just figured Exel was just another knock-off rim company. Thanks for the info. I guess you really do learn something new everyday.
almost bought rh5s last year, glad i got my px-5s instead.
