I still have pretty decent tread on my tires (nanking) but it seems like the two front ones seem to always be lower after I put air in them. Is there some kind of stuff that I can put inside the tire to seal any kind of hole off? I feel if i do put something in there, I would have to replace the tire sooner than I should. I guess if thats the case, i should replace anyway, but i dont understand why it would keep doing that. Its driveable still but it just doesnt seem to stay the way it would have *perfect* amount of air in it. Thanks.
take them off and look for nails
Take them to a tire shop and tell them you have a leak. They'll find it and then either fix it or, if it's on the bead, reseat and rebalance them. Shouldn't cost you much at all.
Alright, well thanks for the responses.
...agreed. if you put that fix-a-flat stuff in it, itll mess up your tire after a while of driving. that stuff is meant for temporary use only. if it is BOTH tires, id say they aren't seated correctly.
...don't hate!.. respect people that have talent, even if it is in something you don't like or understand.
Take em off and buy some non piece of @!#$ tires.
No offense
Haha.. just no love for nankang.
Well my front tires always look a little "pinched" at the bottom from the weight of the front of the car. The back ones always 'look' a little more round at the bottom. even when they have the same amount of air pressure. Your description was kind of vague, so I don't know how drastic your air loss is... so this might be a useless comment.
Words that you can't use in modding: Finished, Perfect, Cheap.
